Community Member
ccm 5 Licensing issues?
Can not join the new license purchased CCM5, upload, when stuck, use the CLI command added, shows the increase in license does not come out, the license file is certainly good, is not CCM5 need a patch package, the original license or easy to use
CCM 5.1.2.3000-2Can not join the new license purchased CCM5, upload, when stuck, use the CLI command added, shows the increase in license does not come out, the license file is certainly good, is not CCM5 need a patch package, the original license or easy to use
CCM 5.1.2.3000-2
Everyone's tags (2)
1 REPLY
Community Member
Can you confirm the license file you have is exactly for CCM 5?
What happens when you adding that file through web interface?
Screenshot?
294
