Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CCM 5 with nokia Nokia E61
I am trying to register nokia E61 in my CCM as sip phone. Any one can guide me little.
Nokia is getting ip addresses from CCM but says registeration failed .. where should i look in..
thanks
Re: CCM 5 with nokia Nokia E61
Configuring the Nokia E61 / E70
Go to Menu - Tools - Settings - Connection - Sip Settings.
This works for me:
Profile name: Merus
Service Profile: IETF
Default Access Point: MyNetwork [you will have to have that defined as an access point]
Public user name: christian2@86.x.x.224 [use the IP address of your Cisco server to avoid DNS problems]
Use Compression: No
Registration: Always On
Use Security: no
Proxy server settings
Proxy server address: sip:86.x.x.224 [use the IP address to avoid DNS problems]
Realm: cisco
User name: christian2
Password: ********
Allow loose routing: Yes
Transport Type: UDP
Port: 5060
Registrar Server Settings
Registrar serv. addr.: sip:86.x.x.224 [use the IP address to avoid DNS problems]
Realm: Cisco
User Name: xxxx
Password: ********
Transport Type: UDP
Port: 5060
Troubleshooting
Make sure you can connect to the access point you defined above (browse the web using the web browser and the same access point)
Switch the Nokia off and on, see if you can see any registration attempts from the Nokia.
Lots of powercycling the Nokia (e.g. switching it off and on) helps ... especially after having made changes
may be we can find out some more informatin from the logs.
this one got registered on Asterisk
Thanks will get back to you after trying ..
no luck man :( tried same thing ... ot says registeration fails..... which logs we shud be looking in.
hi,
in that case i believe we shd look into Ethereal traces pointin (callmanager, access point).. to find out the issue.
212
