CCM 6.0(1) Device Update Error
I ran into an issue that I have not seen before. I updated a device today (7961) by updating the Owner User ID. However, when I select the “Save” button, I received the following error:
“Operation Completes By Date/time must be greater than current date/time.”
I have restarted and reset the phone to no avail. I am not having this issue with any other phones as I have tested several, including other 7961's.
Any thoughts?
Nathan Richie
Re: CCM 6.0(1) Device Update Error
Hi!
Are you using Certification Authority Proxy Function (CAPF)? There was a similar issue with a CAPF file with a smaller date the current date, which
caused the error.
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
Teresa,
We in fact are not using CAPF. However, when I looked at that phone configuration page, the certificate operation was set to Install/Upgrade. I changed it to No Operation Pending, and it works properly now.
Thanks for your assistance!
Nathan Richie
Glad to hear that! Have a nice day!
Do you know how I mark this issue as being resolved? I see where I can rate your post but I do not see where I can mark it resolved.
Nathan
225
