Community Member
CCM 6.0 and Web Dialer - Removing Dialog Box
Web Dialer; Click to Dial from User Directory:
Is there a way of eliminating the user id and password challenge box when using the Web Dialer application within the user Directory function? Not much of an convenience to click dial if I have to answer userid and password everytime.
-gp
Community Member
Re: CCM 6.0 and Web Dialer - Removing Dialog Box
I have the same problem, however I have managed to get one userid that works, not sure have yet but will either find the solution or raise a TAC case with Cisco
Community Member
Understood. My authentication ultimately works fine, but the constant use of the dialog box defeats the purpose of the feature.
Community Member
the answer is:
Bug CSCsm85167
You have to upgrade.
BR,
pedro lourenco
123
