CCM 6.0 Enterprice parameters
Hi. In system -> enterprice parameters
auto attendant installed and ipcc express installed have count false. And i don't find how active this parameters. how me install this options.
1 ACCEPTED SOLUTION
Green
Re: CCM 6.0 Enterprice parameters
DO you in fact perform the IPCC AA integeration?
If so which version,
Green
thanks. let ok.
Hi all
I have same problem. Please tell me how to change IPCC Express intalled into true?
Thank
I did have this issue with an IPCC install not setting the database parameters. My issue was on CCM5.0, but I would expect it to be similar under 6.0.
Run the following query on your CM
admin:run sql select paramname,paramvalue from processconfig where paramname like '%nstalled%'
If you get the following response :
paramname paramvalue
AAInstalledFlag F
IAQInstalledFlag F
Then try this:
run sql update processconfig set paramvalue="T" where paramname like '%nstalled%';
That corrected it for me.
166
