Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
ccm 6.0 NFR installed on vmware
can anybody help with a vmware install, i have tried installing the 6.0 nfr twice into a fresh vmware, but i get right to the end of the install then get a fatal error and the ccm install wants to dump the info to a USB key. I have tried various disk sizes and memory setup to no avail. I have tried to install ccm 5.1 in vmare on the same box with no issues, does anybody have any tips or a vmware config file for the install. This is for a lab setup and not a production site.
Green
Re: ccm 6.0 NFR installed on vmware
have u already tried that 6.0 media in a working server.
Just to verify DVD is ok
good idea i'll try it after christmas, do you have 6.0 NFR working in Vmare, if so which version of Vmware and what are your config option ?
cheer for the suggestion
dave white
ccie #13955
Hi can I assume that we can download an approved VMWare image of Cisco UCM V6.0 from Cisco somewhere and that this is OK to use in a test / lab enviroment ? We have CCM V4.1 and want migrate to V6.0 but would like to test/ play in a VMWAre environment first before we purchase the V6.0 hardware which I have been told is a hardended Linux appliance ? Thanks
disk size:80G
Memory:1G
CPU:Intel
This is my vmware config.
hi could you send me your vmware config file for your setup so i can copy, maybe i have not allowed enough disk space, i went for 30 Gig and 800m ram ?
Green
David attach my VMware config
Green
hi thanks for this, i will try it in are lab when i get back to work after christmas; and let you know how i get on.
can you please repost this?
Bronze
Hi , where can i get a copy of this CCM 6.0 nfr software ? We'd like to test CUOM in our lab, and we need a callmanager. thanks.
net
Could you please repost this?:)
can you send me VMware.zip file for ccm 6.0
basit_masood2002@yahoo.com
Basit
Hi! Gogasca
Could you kindly send me the zip file. We'll try to install CMM 6.0 on VMware for testing.
Hi! Gogasca
Would you kindly send me the vmware config zip file for me to test cmm 6.x in a VM environment?.
This worked fine for me, i now have a working 6.0 in my lab, thanks for all the advice.
Make sure you set hard drive space to 72 Gig. I set memory to 1024 and it works like a charm for 6.0
242
