Community Member
CCM 6.0 to CCM 8.0 upgrade
Hi All,
Sorry if i am being dumb but i currerntly have 6.0 on 2 x MCS7816H3 servers and im proposing to upgrade to CCM8.0 on 2 x new MCS7816I4 servers (i know 8.0 isnt the nest choice but i havnt got a choice on that) the thing is i presume there is a partcode/cost for moving the licenses etc over from the old servers or do i just purchase the 7816I4 with 8.0 on them and away i go!
VIP Super Bronze
Re: CCM 6.0 to CCM 8.0 upgrade
If you have UCSS coverage, you can place a PUT order and order the servers. If not, you will need to purchase an upgrade.
Also be aware that you cannot directly upgrade from 6.0 to 8.0: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html
Community Member
I know i cannot upgrade directly to 8.0 from 6.0 and i also i need to purchase a upgrade but i cannot find what upgrade to get as
i dont know the part number
VIP Super Bronze
Work with your Cisco partner. They will have to place the order for you anyways and have ordering guide documentation for reference to ensure accuracy.
368
