ccm 6.1(2) cdr timestamp show in utc
Our cdr reports in ccm6.1(2)shows utc time instead of local time. How can we change the cdr reports to show local time instead of utc time?
Re: ccm 6.1(2) cdr timestamp show in utc
what do you mean?? if you go to CAR and do a search you get it in UTC? or are you looking at the flat files with a 3rd party??
java
if this helps, please rate
java
www.cisco.com/go/pdi
Both locations show the time in utc, which is 5 hours ahead. Time on callmanagers and phones show the correct time.
CCM 6.1(2)
Community Member
I have the same issue in 6.1(4).  have you had any luck finding a reason or answer
to this?
much thanks.
235
