CCM 6.1.3 Cluster configuration
Hi, I tried to configure a cluster in a CCM version 6.1.3 using wizard option, it ask for the publisher name, Ip address and the the security password but it does not work, at the end of the procedure an error was displayed, is there an other way to do that ?
1 REPLY
Green
Re: CCM 6.1.3 Cluster configuration
make sure u already added the subscriber under ccmadmin, try using ip addresses.
reset security password in publisher (look procedure in forum or cco)
then re-try adding sub
97
