Community Member
CCM 6.1 and 7925
Any suggestion on how to add a 7925 to CCM 6.1? It currently isn't in the list of phones that we can add.
Community Member
Re: CCM 6.1 and 7925
You need to install a device package for for UCM 6.1. Here is the release notes for the latest. This includes device support for the 7925 wireless phone: http://www.cisco.com/web/software/282074299/24559/cmterm-devicepack-6_1_2_1131-1_readme.html
Community Member
awesome, thanks.
Before You Begin
To make the Cisco Unified Wireless IP Phone 7925G or 7921G available in the Cisco Unified Communications Manager system, you might need to upgrade your system with the latest DevPack patch for your release of Cisco Unified Communications Manager. Check the Readme file (cmterm-7925-sccp.1-3-2-Readme.html or cmterm-7921-sccp.1-3-2-Readme.html) that is posted with the firmware version 1.3(2) for more information.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7925g/firmware/1_3_2/english/release/notes/792x_132.html
java
if this helps, please rate
java
www.cisco.com/go/pdi
245
