CCM 6.1 Extension Moblity
akascarface
Where do you subscribe your phones and dev profiles to the Login service like you did in 4.1 in the Admin page?
Jaime Valencia
once you're on the device or device profile on the same row where the icons are on the right side there is a drop-down menu, almost below the one from CCMadmin, OS Admin and serviceability
use that one and look for subscribe services, then click on go
java
if this helps, please rate
Oh WOW thats really easy to miss. Its in the Related Links drop down. I never thought to look there I thought "related links" meant like ..help douments.
