tka
CCM 6.1 HOST file reporting wrong cluster information
Hi all,
I have a CCM 6.1 Cluster. The situation I'm dealing with is that Cisco Unified Reporting-> Unified CM Cluster Overview report wrong informations about subscribers (stating that they provisioned but not installed). These information are picked from the HOST file. In the other hand, The Operation system interface reports right cluster information.
When I do replication repair all, it fails because of a single node cluster, which not really the case. What should I do so the HOST file will reflects reality.
thanks in advance.
best regards,
1 REPLY
Bronze
Re: CCM 6.1 HOST file reporting wrong cluster information
If the name of a node in the database is the IP address of the node then a series of reports fail due to an incorrectly built installed server list. Check the IP address and node name is correct.
119
