Community Member
CCM 6.1 Music on Hold Playlist
We wold like to configure voice messages into a playlist and use as music on hold.  We would like to set it as a playlist so we can easily add or delete each type of promotional message without having to re record all messages.  Is this possible? If so how?
VIP Super Bronze
Re: CCM 6.1 Music on Hold Playlist
Not possible. You will need to use a third-party software utility such as Audacity to mix the individual files into a final single WAV file that you then upload to CUCM.
You can always use the external MOH audio source. Just plug in your ipod with the playlist.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
VIP Super Bronze
Just be careful not to use commercial music if you do this. You legally have to buy additional licenses to play anything that has a copyright that you do not own via MoH. Check with your legal counsel for details depending on your country.
253
