CCM 6.1 (Secure) ATA, VG224 intregration?
I am setting up a Secure CCM System (Customer's wish). The system is at the point where I can make encrypted calls over my IP network. My question is: The customer wishes to add in the use of VG224 and ATA'S. I am assuming that there is no such thing as a Encrypted mode of the ATA, because that is not even a menu choice. Am I missing something?
The next is: How far can I secure the VG224? Is it possible to build an IPSec Tunnel like normal Gateways? Is it even possible to have secure Ananlog Phones?
Thanks in Advance.
Super Bronze
Re: CCM 6.1 (Secure) ATA, VG224 intregration?
ATAs don't support encryption; so that option is not available.
Gateways (including the VG224 according to the data sheet) all support SRTP, so if you connect your analogues to these this should work.
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Thanks for your response. Attached is my config for a VG224 "attempting" to set up a IPSEC tunnel to my CCM. But I keep getting the Message
MM_NO_STATE. Can someone take a glance at it to see what I screwed up.
My Customer wants IPSEC Tunnels between the Gateways and CCM, once the tunnel is up I will turn on SRTP.
204
