ccm 6.1: Transfer a call back to the origional forwarded line
I have a line A that is forwarded to line B. When someone calls line A, line B answers. What needs to be set on Call Manager 6.12 to allow line B to call line A without having to take off the call forwarding feature for line A?
Hall of Fame Super Red
Re: ccm 6.1: Transfer a call back to the origional forwarded lin
Hi there,
Check out Call Forward Override
Cisco Unified CallManager provides a service parameter (CFA Destination Override) that allows the administrator to override Call Forward All (CFA) when the target of the CFA calls the initiator of the CFA, so the CFA target can reach the initiator for important calls. In other words, when the user to whom calls are being forwarded (the target) calls the user whose calls are being forwarded (the initiator), the phone of the initiator rings instead of call forwarding back to the target. The override works whether the CFA target phone number is internal or external.
When the CFA Destination Override service parameter is set to False (the default value), no override occurs. Ensure the service parameter is set to True for CFA override to work. See Service Parameters Configuration in the Cisco Unified CallManager Administration Guide
Cheers!
Rob
Rob:
      Thanks for the information! That worked!
Cheers!
      Hampton
Cannot believe that I was not aware of this
+5 for Rob
excellent, was not aware of that Rob. Now for a hard question, how do I give a 10 star rating when there are only 5 available to choose from? Solve that one stud!
Hi Hampton,James & Tracy,
Thanks all for your nice comments Much appreciated my friends!
We took special note of this feature when it came out in CUCM 5.x
as it duplicated a similar feature from our "old' Nortel.
Cheers!
Rob
288
