ā11-22-2010 07:12 AM - edited ā03-16-2019 02:03 AM
dear all,
I have a requirement as mentioned below
if an end user calls from outside or inside company extesion number the ip phone is ringing if there is no one to pick the call the same call should be trnasfered to my mobile number is it possible to do so in call manager 6.1. please help
ā11-22-2010 07:17 AM
Configure the call forward settings from your phone to dial your mobile.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
ā11-22-2010 08:29 AM
that is correct but i want both to ring Simultaneously
ā11-22-2010 08:32 AM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_0_1/ccmfeat/fsmobmgr.htm
java
ā11-22-2010 09:08 AM
this link is not opening
ā11-22-2010 09:17 AM
Weird, I opened the link about an hour ago and was working fine
java
ā11-22-2010 09:32 AM
thanks for the information... please confirm do we need seperate server to configure mobile connect.
ā11-22-2010 09:34 AM
No, that's wrong. The feature is built-in CUCM.
java
