CCM 6.21 instalaltion in VM failed
i tried to install the CCM6.2.1 in VM.
Following Steps are made:
- download imgae from CCO
- create install disc, because the DVD isn't bootable
- create VM incl. 2Gb RAM, 40 GB HDD
So the VM boot per disc and tried to load the instalaltion files from DVD.
Following message appeares:
"No Read Hat Linux CD was found... Pleas Insert the Read Hat Enterprise Linux CD and press OK ..."
I Thought, the DVD from CCO is a complete Image for installation?
Any ideas?
regards
Ronny
1 ACCEPTED SOLUTION
Re: CCM 6.21 instalaltion in VM failed
uhm if its a DL from CCO its just a patch, CCO does not include full CCM Fresh Install images. They come when you purchase CCM. That is an upgrade patch its probably like 1-2gigs? You need to get a copy of the 6.x Install disc. I believe the newest that has shipped is 6.1.2.
HTH, please rate useful posts.
Chad
Bronze
The images on CCO are not bootable images. You might be able to trick it into working, but there are no guarantees. Increase your disk size to at least 80GB and see if that helps.
Thank you,
Jon
the image itself says it's not bootable, did you read that??
UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part1of2
Release Date: 06/May/2008
Cisco Unified Communications Manager 6.1(2) part 1 of 2 (non-bootable) - For upgrade from 6.0(1)
UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part2of2
Cisco Unified Communications Manager 6.1(2) part 2 of 2 (non-bootable) - For upgrade from 6.0(1)
FOR UPGRADE FROM 6.0(1), you need to ask for the install media using the PUT tool or ordering it directly from Cisco or a re-seller
also your server does not seem to meet the minimum requirements for CUCM, you need at least 72 HDD to install it, otherwise it will fail
java
if this helps, please rate
java
www.cisco.com/go/pdi
Chad
120
