03-31-2009 06:24 AM - edited 03-15-2019 05:12 PM
We're accepting CDR data for a customer from several vendors' solutions. Cisco is one of them. The problem is we are working in sort of a vacuum. The customer recently switched all their 5 digit extensions to 10 digits. Assuming we have very limited knowledge of the partitioning and details of the network setup for Cisco, how do we deal with the CDR?
Specifically, how do we reliably tell incoming calls from outgoing and internal calls? It was pretty painless in the past when the extension digits were shorter. Dialed digits were easily determined just by comparing lengths. Now however, short of knowing every possible extension ahead of time (they are actually combining CDR from dozens of sites into one FTP feed to us), it has become practically impossible to process the calls.
Given the limitations of our knowledge of the Cisco setup, is there a reliable way to determine the type of call in the raw CDR file?
03-31-2009 06:42 AM
You may take a look at
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_0_1/cdr-defs/cdrfdes.html
Michael
03-31-2009 06:53 AM
Thanks for the reply. I've pratically got that table memorized at this point.
What combination of fields should I be looking at if the callingPartyNumber is 10 digits, and the FinalCalledPartyNumber is also 10 digits?
It that an incoming call with ANI, an outgoing call with dialed digits, or an internal call (station to station)?
Without knowing the patitioning scheme on the Cisco end, I can't figure out any combination of the fields that can give me the answer.
-Brian
