CCM 6 Fax question
I've been reading around this... is this possible ?
I am using a 1760 as my Gateway, I have FXS and FXO, I would like to have voicecalls inbound on the FXO go to CCM and onto IP Phones, and the FAX to go to the fax machine on the local FXS port.
1. is this possible ?
2. is this possible from within CCM6 or would i need to tweak the router / use CCME ?
huge thanks... Will
1 REPLY
Re: CCM 6 Fax question
Will,
Here's one option.
http://www.faxswitch.com/stick.html
This device will detect whether an incoming call is voice or fax. You could put this between the demarc and your gateway/fax machine. It will send voice calls to the gateway and faxes to the fax machine. In this scenario you wouldn't need to have the fax plugged into the FXS, unless you want it to use the system for toll bypass/TEHO.
Hope this helps. If so, please rate the post.
Brandon
103
