Community Member
CCM 6 to 7 upgrade
Hi, is there any way to upgrade CCM 6 to 7 such that all licenses upgarded automatically? or something such as export licenses and importing to new installation? my problem is that i don't have any info like PAK or serial number of my license on CCM 6, only i have installed server
Re: CCM 6 to 7 upgrade
the license will migrate if you do it on the same server, but you do need to have the new CUCM 7.X feature license to activate the services after the upgrade.
you will still have the one for 6.X but it won't allow you to start services in 7.X as it's version specific
if you're changing HW you will need to reach licensing to have them rehosted.
java
if this helps, please rate
java
www.cisco.com/go/pdi
Bronze
You'll have to have the UCCS subscription when you open a TAC case with the licensing team to get your licenses transfered.
123
