CCM 6.X Interdigit timer
I can't find the paramater for the interdigit timer in CCM 6.X, can anyone tell me where this is? I thought it would be under service paramaters.
1 ACCEPTED SOLUTION
Re: CCM 6.X Interdigit timer
it is under "system - service parameters" then select the ip of your callmanager and select the callmanager service. You are then looking for the T302 timer.
Please rate helpful posts.
Mike
1 REPLY
Mike
155
