Community Member
CCM 7.0 integration with 3rd party billing system
CCM 7.0 is required to integrate with a 3rd party billing system, what configurations required in this regard on CCM.
What are the pre-requisites for billing system to be compatible with CCM 7.0?
Re: CCM 7.0 integration with 3rd party billing system
All you need to do is configure the billing server on CUCM
Configuring CDR Repository Manager
Get in touch with the billing server vendor to make sure it's compatible with CUCM 7.X
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
If the billing software is not compatible, the billing system developer would like to know the CDR database schema to customize the billing software. From where these details can be obtained?
As per my understanding from your reffered link the publisher will be CDR Repository Manager & each subscriber in the cluster will be agent, please correct if I am wrong.
Cisco Call Detail Records Field Descriptions
Further help needs to be obtained from our DEV program.
java
java
570
