CCM 7.0, Unit connection 7.0 Auto Attendant
dcoulanges
How to configure Auto Attendant or where is the documentation ?
Jaime Valencia
there is no specific documentation for AA.
it's all based in using call handlers to create the options and using the caller input to route calls.
if you know how to configure those 2 things that's all you need to configure AA
java
if this helps, please rate
java
hi java that is the same to UC 2.1?
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
Jaime Valencia
The same basic concept applies to any CUC or Unity version.
It's all call handlers and caller input options.
java
java
ok
thank's
Cheers
Bruno Rangel
