Community Member
CCM 7.13B
I recently installed a new Sub with an ip address of 10.4.140.15 into our existing cluster , however when I run the data base replication report , I noticed the following 2 errors
1) The onconfig.ccm file on 10.4.140.15 does not match the publisher.
2) The sqlhosts file on 10.4.140.15 does not match the publisher
Any idea
1 REPLY
Re: CCM 7.13B
Have you performed a cluster reboot after adding the new SUB?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
357
