CCM and Unity together?
Can Call Manager and Unity be run on the same machine, or do we have to run it on two machines?
1 ACCEPTED SOLUTION
Bronze
Re: CCM and Unity together?
Read the 3rd to the last line here under Important Considerations. Says in plain text to NOT install Unity on a CallManager server.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/install/instcall/cm413ins.htm#wp532686
Silver
you have to run each of them in separate machines.
Is there anywhere on Cisco's website that says they have to be seperate? I need some proof to take to the client. I haven't been able to find anything.
Bronze
Hall of Fame Super Red
Hi David,
Here is a note to add to Zin's good info and to pass along to your Management;
Which Cisco IP telephony applications may I install on the Cisco CallManager server?
Consider the following information before you install other software besides Cisco CallManager on the Cisco MCS or the customer-provided server:
You can install a compatible version of Cisco Customer Response Solutions (CRS), which you must purchase separately from Cisco CallManager.
**Do not install Cisco Unity**, Cisco Conference Connection, Cisco Personal Assistant, or Cisco Emergency Responder on the server where Cisco CallManager is installed.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_installation_guide_chapter09186a00803fd706.html#wp1040352
Hope this helps!
Rob
Green
Hi David,
CCM 6.0 (UC 6.X) will have that capability Unity Connection and CCM running in the same box.
118
