Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CCM Calling Search Space and Partitions
I saw in the SRND that 500 locations are supported. What are the restrictions on Calling search space and Partitions of CCM.
Best regards,
Piet.
Bronze
Re: CCM Calling Search Space and Partitions
This isn't a direct answer, but I do know the number of partitions in a single CSS is a function of the partition names. And, as a general practice you would want more partitions than you could put in a single CSS. Check out this table:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a0080181a46.html#26766
Silver
I don't think there is a maximum number of partitions or calling search spaces you can have. Well, there probably is, but I don't think you have to worry about it. It's likely an SQL table thing.
However, there is a maximum to the number of partitions you can include in a calling search space. The problem is, it's character based, not unit based. There is a maximum of 1024 characters in a combined calling search space which is device + line, so that means 512 characters including the delimiter "," for each individual calling search space. For example, if your partitions are 20 characters long, (512 - 20) / 20 = 24 partitions per css. The minus 20 is for 20 seperators.
So, don't go overboard with your naming convention, short and sweet but meaningful.
688
