CCM cannot register the voice gateway
After configuring the voice gateway, the command 'sh ccm-manager' shows me that the CCM is registered from the voice gateway, but from the the CCM GUI the status is REGISTRATION : Not registrered
IP Address : unknown.
Could you please help !!
NOT REGISTERED. The call manager c
1 ACCEPTED SOLUTION
Re: CCM cannot register the voice gateway
that link is not even working, layer 2 is down
check the framing, line-code and also the isdn switchtype. maybe you'll need to call your telco to verify your settings are correct to get the link up
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
does the domain name in cucm matches the hostname + domain if configured?
is the right ISR model selected?
are you configuring the right card in the right slot??
do you already have all the config in the ISR?
if you have dial-peers do they have the application mgcpapp configured??
if possible post your config and let us know the servers ip
BTW, show ccm only shows the udp keepalives being sent and received, not the real registration
javalenc
java
The voice-gateway is a 2801 with VWIC-2MFT-E1 in slot 1, no pb for this.
Pls find enclosed the config file.
The CCM ip address is 10.100.9.225 and the voice gateway have on Fast0/1 the address 10.100.9.230.
Bst
Hi, Can you confirm what is the output when you use the "sh isdn status" command. Does the Layer2 shows "Multiple Frame Established" or "TEI Assigned".
Also confirm whats the model of Router you are using.
Here the router type :
flash:c2801-advipservicesk9-mz.124-11.T_64_192.bin
card : VWIC-2MFT-E1 / PVDM2-64
It shows TEI_ASSIGNED
javalenc
java
270
