CCM CME Integration
I connected CCM 4.1(3) and CME 3.3 and create an ICT in CCM.Also created 1 voip dial-peer in CME for calls to CCM
dial-peer voice 7 voip
destination-pattern 7....
session target ipv4:192.168.1.75(CCM IP)
codec g711ulaw
Calls from CCM to CME is working fine. But when i am trying to call from CME phones to CCM phones it is getting busy tone.
Also I have 1 CUE in CME Router. VoiceMail system is working properly from CME phones. But when i call VoiceMail number from CCM phones, it is getting busy tone.
Pls help
Thanks........
1 ACCEPTED SOLUTION
Re: CCM CME Integration
try to define CME as h323 gateway on CCm instead of ICT and use ur dial peer on CME to point to CCM
Sadiq,
For CME to CCM calls, make sure the ICT trunk has a CSS that gives it visibility to the partition that the CCM phones are in. Also make sure that the number being delivered (7xxxx) is what the CCM is expecting.
For CCM to CUE calls, confirm that CCM calls are coming in as G.711, otherwise a transcoder would be needed to translate the call since CUE only speaks G.711. Ensure also that H.323 to SIP routing is enabled.
voice service voip
allow-connections h323 to sip
If your configuration looks alright and calls still fail, feel free to post your configs and output of debug voip ccapi inout as well as CCM traces.
Michael.
hi Michael
i am just wondering why he made the integration as ICT to CME?
through the ICT the CME will comunicate as h323 device with CCM?
i think its easier and better to make the intgration as h323
he can define the CME as h323 device and at the CME do the dial-peer he has done
i think more reliable
Sadiq, this is a link to a prevous discussion addressed a case similer to urs
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc1bb67/0#selected_message
if helpful Rate
The CCM to CUE issue solved when i configured voice service. But the CME to CCM calls still not working. CCM phone CSS and ICT trunk CSS are same. Here i m attaching the debug ccapi inout output.
Pls give me a solution.
Thanks.......
Hi Marwan,
I couldn't find any specific technical reason for using an ICT vs a gateway. Do you know any technical reasons for using one and not the other? I agree that configuring a gateway is often simple. The CME doc that refer to integration with CallManager reference using an ICT. Here's an example.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmetrans.html#wp1121584
Sadiq - the traces show the following error message:
*Mar 1 17:30:47.275: //60/E2E8D004803B/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x84910EAC, Tag=0x0, Call Id=60,
Call Entry(Disconnect Cause=38, Voice Class Cause Code=0, Retry Count=0)
Disconnect Cause=38 means Network out of order: Destination cannot be reached because the network is not functioning correctly, and the condition might last for an extended period of time. An immediate reconnect attempt will probably be unsuccessful.
To try to fix this, try the following:
1. Verify that the CallManager can ping the CME gateway.
2. Go to the CME router and on the interface that has the IP address used in the ping test in #1, add this command:
h323-gateway voip bind srcaddr x.x.x.x
Test again. If still failing, run the same debug as before, and also debug h225 asn1 and debug h245 asn1.
Hope this helps.
Michael.
The issue is resolved. i added h323-gateway voip bind srcaddr x.x.x.x to the interface. Now it is working fine.
Thanks guys.........
Sadiq.
Sadiq,
What are you doing to make a call from ccm to cme.
I have two cme for redundancy but can not define both under route list. Can you help me.
Thanks in advance
anwar ahmed
hi anwar
gdefine each CME on CCM as h323 gateway
then put each one in diffrent route group
then put those route groups in a route list
and make sure u put them in the right sequence
good luck
if helpful Rate
hi Michael
there is a need for ICT in the following case
Cisco CallManager (as of release 4.0) does not support H.450.x services, including H.450.12. However, Cisco CME 3.1 (and above) automatically detects a call that involves a Cisco CallManager using special H.323 nonstandard information elements (IEs). Even without an H.450.12 indication, Cisco CME's automatic Cisco CallManager detection can be used to invoke VoIP-to-VoIP hairpin or tandem call routing when needed for call transfer and forwarding. You need to enable the allow-connections h323 to h323 command to make this work.
Some special configuration of the H.323 interface on Cisco CallManager may also be required, depending on the specific Cisco CallManager software version used. For example, you may be required to configure a Media Termination Point (MTP), disable H.323 Fast, Start, and use Cisco CallManager's H.323 Inter-Cluster Trunk (ICT) mode
hope this helpful
Thanks for the information, Marwan. +5 for your good input here.
Michael.
u welcome
and thanks for Rating :)
808
