CCM conference
Hi all, do somebody know, how many conference connections can be used on 7835 MCS server with CCM 4.2? I dont have transcoder, but I think that server alone can mix some conferences. If you know link it would be nice. Cannot find on cisco.com even if I tried. THX
1 ACCEPTED SOLUTION
Re: CCM conference
go to the CCM enterprise parameters and look ad-hoc conference
128 / parameter value = total conferences at same time
default is 4 conferencees
128/4 = 32 conferences
Only G711 on SW CFB and it's not recommended to set the parameter over 48. since that causes some high cpu due to the allocation of resources.
maybe you should have tried looking at NetPro, this has been asked millions of times here =). Please try searching previous posts.
look in the media resources section of SRND for CUCM 4.x info should be there
java
if this helps, please rate
java
www.cisco.com/go/pdi
Re: CCM conference
java
java
Re: CCM conference
Thanks very much, Im always forgetting to search in posts, sometimes its more helpful than search on cisco.com.
90
