CCM confernce:using 2 device pool
I'm using CCM6 with a Voip call.
The VoIP Call use G729 codec.
The internal call use G711.
I use a IOS MTP with G729 Codec.
If I use the Default DevicePool,
I cannot call through the VoIP.
So I've created a new Device pool that use another region with G729 COdec. and I can call with the VoIP.
Now all work fine, but only the conference with the Voip Call is now blocked.
Is it possible to communicate the 2 device pool? The first use g711 and the other use g729.
Is IOS Conference bridge can be a solution?
thks
Hall of Fame Super Red
Re: CCM confernce:using 2 device pool
Hi Solo,
You are right on the money my friend :) You are seeing this restriction that applies to Software Conference Bridges;
This really sounds like a Codec issue. Have a look;
Cisco CallManager Software Conference Bridge supports only G.711 a-law and G.711 u-law and does not understand any other codec such as G.729.
From this Conferencing doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008009476a.shtml
Hope this helps!
Rob
Yes I want a codec issue,
And now I cannot configure the MTP.
My Router have 2 PVDM2-64 and two Ethernet interfaces.
I've put the first interface for MTP, and the sercond for transcoder.
The MTP can be registered but the second (Transcoder) is Rejected.
Have you any issues?
This is the configuration :
sccp local GigabitEthernet0/1
sccp ccm 192.168.20.3 identifier 2 version 5.0.1
sccp ccm 192.168.20.2 identifier 1 version 5.0.1
sccp ip precedence 3
sccp
sccp ccm group 1
bind interface GigabitEthernet0/1
associate ccm 1 priority 1
associate profile 111 register TXC001CF6FB1E00
associate profile 1 register MTP001CF6FB1E01
dspfarm profile 111 transcode
description transcode profile 111
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
codec g729r8
maximum sessions 4
associate application SCCP
dspfarm profile 1 mtp
description Software MTP
codec pass-through
codec g729r8
maximum sessions software 400
I'm Trying this :
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008084fe1f.shtml
I've configured 2 device pool, the VoIP call cannot be established if i use the DevicePool for all ipphones and servers.
The first Device pool is configured with region with g711 codec, and the second for the VoIP is configured with g729.
They're based on the region, and i'm not good with regions.
Any issues?
139
