ccm configuration log
mike.lo
Due to audit issue, can ccm or unity support configuration log?
Rob Huffman
Hi Mike,
For Callmanager try MLA (Multi Level Administration)
Access Logs
Multilevel administration access generates a log with a record of login attempts. The log includes the user name, group name, date, time, and success or failure status of the login session.
A file contains a file report of access/change attempts. That is, multilevel administration access generates a record of attempts to access or modify any directory or database component through the Cisco CallManager system administration. The change record includes the user name, date, time, menu accessed, web page from which the change was made, and the success or failure status of the update.
Find the log file under the Log directory in c:\ciscowebs\MLA\logs, filename MLALogxx.log (where xx are numeric digits).
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a0080490d52.html#wp1025731
Installing Multilevel Administration Access
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a0080490d5e.html
For Unity;
Check out Unity Reports and see if this gives you the info you are looking for.
SAWeb > Reports > System > Administrative Access
Hope this helps!
Rob
Unless there have been major changes, the MLA logs only have the URL the user used to make the change. It does not have before/after settings.
Check out Arcana, I've not used their product, but have been meaning to.
http://www.arcananetworks.com/Products/MeVoIP.asp
tks, for ccm 4.1(3), it has build-in MLA and the log is located in C:\Program Files\Cisco\Trace\MLA.
