CCM core dump 8.5.1 SU1
Anyone seen this core dump before on ccm process?  Not finding any bugs that match on cisco / hot RSS feeds / etc yet. I know should probably do SU3 or latest 8.6, but wondering if anyone seen this before...
Syslogs at time of CCM service core dump. This was just before midnight when system use is low and there was nothing really going on, no backup active yet, etc. Traces gone from time of the dump.
Date: Mar 6 23:21:47
Machine Name: CCM
Severity: Critical
App ID: Cisco CallManager
Message: : 46640: CCM: Mar 07 2012 05:21:47.961 UTC : %UC_CALLMANAGER-2-CallManagerFailure: %[HostName=CCM][IPAddress=1.2.3.4][Reason=4][Text=][ClusterID=CCM-Cluster][NodeID=CCM]: Indicates an internal failure in Unified CM
Machine Name: CCM
Severity: Critical
Message: : 46641: CCM: Mar 07 2012 05:21:47.961 UTC : %UC_CALLMANAGER-2-CallManagerFailure: %[HostName=CCM][IPAddress=1.2.3.4][Reason=4][Text=CCM Intentional Abort: SignalName: StationInitKeepAliveTimeout, DestPID: StationInit[2:100:50:1]][ClusterID=CCM-Cluster][NodeID=CCM]: Indicates an internal failure in Unified CM
Core Dump Analysis:
Continue (y/n)?y
Using host libthread_db library "/lib/tls/libthread_db.so.1".
Core was generated by `/usr/local/cm/bin/ccm'.
Program terminated with signal 6, Aborted.
Reading symbols from /lib/csa/libcsa.so.6...done.
Loaded symbols for /lib/csa/libcsa.so.6
Reading symbols from /usr/local/cm/lib/libuuidpp.so...done.
Loaded symbols for /usr/local/cm/lib/libuuidpp.so
Reading symbols from /usr/local/cm/lib/libJNIPIWriter.so...done.
Loaded symbols for /usr/local/cm/lib/libJNIPIWriter.so
Reading symbols from /usr/local/cm/lib/libpcre.so.0...done.
Loaded symbols for /usr/local/cm/lib/libpcre.so.0
Reading symbols from /usr/local/cm/lib/libdbnotify.so...done.
Loaded symbols for /usr/local/cm/lib/libdbnotify.so
Reading symbols from /usr/local/cm/lib/libldap-2.4.so.2...done.
Loaded symbols for /usr/local/cm/lib/libldap-2.4.so.2
Reading symbols from /usr/local/cm/lib/liblber-2.4.so.2...done.
Loaded symbols for /usr/local/cm/lib/liblber-2.4.so.2
Reading symbols from /usr/local/cm/lib/libdbl.so...done.
Loaded symbols for /usr/local/cm/lib/libdbl.so
Reading symbols from /usr/local/cm/lib/libpreferences.so...done.
Loaded symbols for /usr/local/cm/lib/libpreferences.so
Reading symbols from /usr/local/cm/lib/libodbc++-mt.so.4...done.
Loaded symbols for /usr/local/cm/lib/libodbc++-mt.so.4
Reading symbols from /usr/local/cm/db/informix/lib/cli/libifdmr.so...done.
Loaded symbols for /usr/local/cm/db/informix/lib/cli/libifdmr.so
Reading symbols from /usr/local/cm/db/informix/lib/cli/libthcli.so...done.
Loaded symbols for /usr/local/cm/db/informix/lib/cli/libthcli.so
Reading symbols from /usr/local/cm/db/informix/lib/esql/libifgls.so...done.
Loaded symbols for /usr/local/cm/db/informix/lib/esql/libifgls.so
Reading symbols from /usr/local/cm/lib/libCryptoUtil.so...done.
Loaded symbols for /usr/local/cm/lib/libCryptoUtil.so
Reading symbols from /usr/local/cm/lib/libxerces-c.so.27...done.
Loaded symbols for /usr/local/cm/lib/libxerces-c.so.27
Reading symbols from /usr/local/platform/lib/libACE.so.5.5.1...done.
Loaded symbols for /usr/local/platform/lib/libACE.so.5.5.1
Reading symbols from /usr/local/cm/lib/libstlport.so.5.1...done.
Loaded symbols for /usr/local/cm/lib/libstlport.so.5.1
Reading symbols from /lib/libresolv.so.2...done.
Loaded symbols for /lib/libresolv.so.2
Reading symbols from /usr/local/cm/lib/libcurl.so.4...done.
Loaded symbols for /usr/local/cm/lib/libcurl.so.4
Reading symbols from /usr/lib/libz.so.1...done.
Loaded symbols for /usr/lib/libz.so.1
Reading symbols from /lib/libcap.so.1...done.
Loaded symbols for /lib/libcap.so.1
Reading symbols from /lib/libgcc_s.so.1...done.
Loaded symbols for /lib/libgcc_s.so.1
Reading symbols from /lib/tls/libc.so.6...done.
Loaded symbols for /lib/tls/libc.so.6
Reading symbols from /lib/tls/libpthread.so.0...done.
Loaded symbols for /lib/tls/libpthread.so.0
Reading symbols from /lib/tls/libm.so.6...done.
Loaded symbols for /lib/tls/libm.so.6
Reading symbols from /lib/tls/librt.so.1...done.
Loaded symbols for /lib/tls/librt.so.1
Reading symbols from /lib/libdl.so.2...done.
Loaded symbols for /lib/libdl.so.2
Reading symbols from /lib/tls/libuuid.so.1...done.
Loaded symbols for /lib/tls/libuuid.so.1
Reading symbols from /usr/local/cm/db/informix/lib/esql/libifglx.so...done.
Loaded symbols for /usr/local/cm/db/informix/lib/esql/libifglx.so
Reading symbols from /lib/libcrypt.so.1...done.
Loaded symbols for /lib/libcrypt.so.1
Reading symbols from /usr/lib/libstdc++.so.6...done.
Loaded symbols for /usr/lib/libstdc++.so.6
Reading symbols from /usr/lib/libidn.so.11...done.
Loaded symbols for /usr/lib/libidn.so.11
Reading symbols from /usr/lib/libgssapi_krb5.so.2...done.
Loaded symbols for /usr/lib/libgssapi_krb5.so.2
Reading symbols from /usr/lib/libkrb5.so.3...done.
Loaded symbols for /usr/lib/libkrb5.so.3
Reading symbols from /lib/libcom_err.so.2...done.
Loaded symbols for /lib/libcom_err.so.2
Reading symbols from /usr/lib/libk5crypto.so.3...done.
Loaded symbols for /usr/lib/libk5crypto.so.3
Reading symbols from /lib/ld-linux.so.2...done.
Loaded symbols for /lib/ld-linux.so.2
Reading symbols from /lib/libnss_files.so.2...done.
Loaded symbols for /lib/libnss_files.so.2
Reading symbols from /usr/local/cm/db/informix/lib/esql/igo4a304.so...done.
Loaded symbols for /usr/local/cm/db/informix/lib/esql/igo4a304.so
#0  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
backtrace
#1  0x04fd4825 in raise () from /lib/tls/libc.so.6
#2  0x04fd6289 in abort () from /lib/tls/libc.so.6
#3  0x08426127 in preabort () at ProcessCMProcMon.cpp:80
#4  0x084276b3 in CMProcMon::verifySdlTimerServices () at ProcessCMProcMon.cpp:774
#5  0x08427ed8 in CMProcMon::callManagerMonitorThread (cmProcMon=0xb25528b0) at ProcessCMProcMon.cpp:411
#6  0x008a2bf3 in ACE_OS_Thread_Adapter::invoke (this=0xcb95ce8) at OS_Thread_Adapter.cpp:94
#7  0x008630a3 in ace_thread_adapter (args=0x0) at Base_Thread_Adapter.cpp:137
#8  0x0045a3cc in start_thread () from /lib/tls/libpthread.so.0
#9  0x05078f0e in clone () from /lib/tls/libc.so.6
info registers
eax            0x0     0
ecx            0x6adc   27356
edx            0x6      6
ebx            0x783    1923
esp            0x6a3aba4        0x6a3aba4
ebp            0x6a3abb8        0x6a3abb8
esi            0x6adc   27356
edi            0x50d7ff4        84770804
eip            0x93c7a2 0x93c7a2
eflags         0x202    514
cs             0x73     115
ss             0x7b     123
ds             0xc02d007b       -1070792581
es             0x7b     123
fs             0x0      0
gs             0x33     51
info threads
   49 process 1923  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  48 process 10476  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  47 process 23835  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  46 process 23864  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  45 process 23865  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  44 process 23882  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  43 process 24085  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  42 process 24100  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  41 process 24102  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  40 process 24450  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  39 process 24451  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  38 process 24498  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  37 process 27251  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  36 process 27252  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  35 process 27253  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  34 process 27254  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  33 process 27255  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  32 process 27256  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  31 process 27257  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  30 process 27258  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  29 process 27331  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  28 process 27332  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  27 process 27333  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  26 process 27334  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  25 process 27335  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  24 process 27336  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  23 process 27337  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  22 process 27338  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  21 process 27339  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  20 process 27340  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  19 process 27341  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  18 process 27342  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  17 process 27343  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  16 process 27344  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  15 process 27345  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  14 process 27346  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  13 process 27347  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  12 process 27348  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  11 process 27349  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  10 process 27350  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  9 process 27351  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  8 process 27352  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  7 process 27353  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  6 process 27354  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  5 process 27355  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  4 process 27357  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  3 process 27358  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
  2 process 27359  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
* 1 process 27356  0x0093c7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
Do you have any answer about this issue? we have the same problem also with the same version
thanks in advance
No, I did not find solution for this yet and it has only happened the one time.
The core dumps were related to a ccm loop
479
