Silver
CCM/CUCM - Alpha Call ID
Is it possible to set the Call ID name for outbound calls from CCM/CUCM. I've read that the Alerting Name on a device's line specifies the Call ID name, but am looking for clarification.
Obviously, this depends on our carrier passing whatever we send them which they don't typically do for the name but can do for the number up on request. At least in the US.
thanks,
Will
1 ACCEPTED SOLUTION
Re: CCM/CUCM - Alpha Call ID
yes, it's the alerting name
java
if this helps, please rate
java
www.cisco.com/go/pdi
PRI or CAS?
Silver
PRI
yes, that's correct. just go to the GW config in CUCM and check
"Display IE delivery"
also as you already noted not all Telcos have this capability so best check with them before doing any changes in CUCM
java
java
Silver
So check "Display IE Delivery" to allow, but where is it set? In the "Alerting Name" on the device lines?
as i mentioned, under gateway config on CUCM
java
java
Silver
Right. I understand. But where is the actual call id name value set? In the "Alerting Name" field on the phone lines?
thanks,
Will
java
java
Silver
Nice!
Thanks much,
Will
128
