Community Member
CCM end call
Hi i have next sheme CCM6.1 -> 2821 with vic2/4fxo and em-hda-6fxo-> PBX -> pstn.
All incoming call goto over vic2/4fxo on ip phone. Then secretary transfer call on pbx over em-hda-6 fxo and subscriber end call to hang up the receiver. Port on vic2/4fxo and em-hda-6fxo not remain in status UP. How i can fix it?
cptone RU
timeouts call-disconnect 1
timeouts ringing 5
timeouts wait-release 1
timing hookflash-out 500
connection plar opx 460
caller-id enable
voice-port 0/1/1
cptone RU
timeouts ringing 5
caller-id enable
voice-port 0/1/2
cptone RU
timeouts ringing 5
caller-id enable
voice-port 0/1/3
cptone RU
timeouts ringing 5
caller-id enable
voice-port 2/0/0
voice-port 2/0/1
voice-port 2/0/2
voice-port 2/0/3
voice-port 2/0/4
voice-port 2/0/5
voice-port 2/0/6
voice-port 2/0/7
voice-port 2/0/8
cptone RU
timeouts ringing 5
caller-id enable
voice-port 2/0/9
cptone RU
timeouts ringing 5
caller-id enable
voice-port 2/0/10
cptone RU
timeouts ringing 5
caller-id enable
voice-port 2/0/11
cptone RU
timeouts ringing 5
caller-id enable
voice-port 2/0/12
cptone RU
timeouts ringing 5
caller-id enable
voice-port 2/0/13
cptone RU
timeouts ringing 5
caller-id enable
dial-peer voice 2000 voip
destination-pattern ...
session target ipv4:10.10.18.5
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 2001 voip
incoming called-number .
codec g711ulaw
no vad
dial-peer voice 101 pots
preference 8
destination-pattern 9T
port 0/1/0
dial-peer voice 102 pots
preference 9
port 0/1/1
dial-peer voice 103 pots
preference 10
port 0/1/2
dial-peer voice 104 pots
preference 7
port 0/1/3
dial-peer voice 2002 voip
shutdown
destination-pattern 66401
codec g711ulaw
no vad
dial-peer voice 208 pots
preference 1
port 2/0/8
dial-peer voice 209 pots
preference 2
port 2/0/9
dial-peer voice 210 pots
preference 3
port 2/0/10
dial-peer voice 211 pots
preference 4
port 2/0/11
dial-peer voice 212 pots
preference 5
port 2/0/12
dial-peer voice 213 pots
preference 6
port 2/0/13
1 REPLY
Bronze
Re: CCM end call
It may be necessary to shut/no shut the voice port to have the changes take effect.
If not, then it would seem that any caller-id information received from the VG224 phone overrides the station-id configs. Can you configure the VG224 phone to not send any caller-id information.
In the planned topology, the FXO port was connected to the Intercom system. Would the intercom system be sending caller-id information like the VG224 phone is doing? If not, then the station-id info would be sent.
208
