Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CCM Ericsson H323 integration
I am trying to connect an Ericsson MD110 with an IPLU card via H323 to CUCM 6.1 without much success.
Has anyone attempted this sort of config before? All of the integration notes have TDM connections on the Ericsson end.
Andrew
Green
Re: CCM Ericsson H323 integration
Try different options:
1. Configure H323 GW in CCM
a.Try MTP only using G711
b Try Fast start (Outbound Inbound)
c Enable Wait for far end H245 caps
d. Check codecs
2. Configure it as ICT
Thanks for the response.
I have tried a,b,c,d and calls from the Cisco to Ericsson ring, connect and then drop after ~10 seconds. Incoming calls from the Ericsson to the Cisco ring but don't connect.
I'll try an ICT.
325
