Community Member
CCM Express as CUCM Fallback
I would like to use CCM Express as a CUCM Fallback using CCME/SRST Functionnality.
But I would like to configure by myself ephone and ephone-dn (not using auto provision).
The point is when I try to create an ephone-dn, it is always up (show dial-peer voice summary). So when a call comes into my gw when CUCM is up (normal mode), it is routed to CCM Express and not to CUCM.
If I let the GW create ephone and ephone-dn automatically, everything is ok. Indeed, when a phone unregister from ccm express, the dialpeer is down so that the call can be routed to CUCM.
Is there any way to configure that ? Is it a normal behavior ?
VIP Super Bronze
Re: CCM Express as CUCM Fallback
Have a look at this document and see if it helps...
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hall of Fame Super Silver
You can solve your problem by applying "no huntstop" to all ephone-dns.
Community Member
Thanx for your answer.
Unfortunately, it does not work.
I think I understood why .... That's because I configured call-forward noan/busy. So when a call comes into an ephone not registered, it is forwarded to another number.
I would need a call-forward unregistered but this functionnality does not seem to be available in CUCME, doesn't it ?
Community Member
I had the same issue.
no huntstop does not help because the dial-peer is still active and it has closer match.
The only workaround I found is to create the dial-peers for each extension and give it lower priority. But if you have 200-300 users... Also ephone dial-peer have $ at the end of each destination pattern which means even closer match then just extension and therefore the dial-peer for ccm must contain the $ as well.
