Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CCM File not found inside tftp()
I have noticed that some (possibly all) of my handsets show quickly flash a "File Not Found" message on the screen after booting. Looking at the trace files for TFTP service, I see a similar log entry (shown below).
All phones are in the should have the same local (English United Kingdom) and phones autoregister.
When I look in the "Enterprise Parameters", although I can set default networks locale to "UK" I the only option I have for default user local is "English United States".
Sample of TFTP trace :
10/03/2007 08:37:24.456 TFTP| CTftpConnect::tftp[4572:[**part address removed**]20.44:50388] File not found inside tftp() [English_United_States/SCCP-dictionary-ext.xml]|<CLID::[**CCM hostname removed**]-Cluster><NID::[**part address removed**]200.1>
10/03/2007 08:37:24.909 TFTP| CTftpConnect::tftp[4572:[**part address removed**]20.44:50390] File not found inside tftp() [English_United_States/7960-dictionary-ext.xml]|<CLID::[**CCM hostname removed**]-Cluster><NID::[**part address removed**]200.1>
10/03/2007 08:49:54.926 TFTP| CTftpConnect::tftp[4572:[**part address removed**]10.21:14847] File not found inside tftp() [United_Kingdom/gk000f909bdaa1]|<CLID::[**CCM hostname removed**]-Cluster><NID::[**part address removed**]200.1>
10/03/2007 08:49:54.941 TFTP| CTftpConnect::tftp[4564:[**part address removed**]10.21:14849] File not found inside tftp() [United_Kingdom/gkdefault.cfg]|<CLID::[**CCM hostname removed**]-Cluster><NID::[**part address removed**]200.1>
10/03/2007 08:54:35.123 TFTP| CTftpConnect::tftp[4564:[**part address removed**]40.45:50383] File not found inside tftp() [English_United_States/SCCP-dictionary-ext.xml]|<CLID::[**CCM hostname removed**]-Cluster><NID::[**part address removed**]200.1>
10/03/2007 08:54:35.670 TFTP| CTftpConnect::tftp[4564:[**part address removed**]40.45:50385] File not found inside tftp() [English_United_States/7960-dictionary-ext.xml]|<CLID::[**CCM hostname removed**]-Cluster><NID::[**part address removed**]200.1>
10/03/2007 08:59:25.805 TFTP| CTftpConnect::tftp[4564:[**part address removed**]20.242:50378] File not found inside tftp() [English_United_States/SCCP-dictionary-ext.xml]|<CLID::[**CCM hostname removed**]-Cluster><NID::[**part address removed**]200.1>
10/03/2007 08:59:26.243 TFTP| CTftpConnect::tftp[4564:[**part address removed**]20.242:50380] File not found inside tftp() [English_United_States/7960-dictionary-ext.xml]|<CLID::[**CCM hostname removed**]-Cluster><NID::[**part address removed**]200.1>
Any ideas ?
300
