CCM Grouping and SRST testing
jcsmith96
I have a site that is part of a CCM Group with a gateway that has SRST. What is the best method for testing both separately.
Jaime Valencia
you can try just unplugging the CCM servers from the network
you can also enable an ACL to block the SCCP communication between servers and phones
java
if this helps, please rate
Brian Lavallee
Just route any packets for each of your CCM servers to "Null 0" on the gateway.
ip route x.x.x.x 255.255.255.255 null 0
all the above or just similuate a wan outage - shutdown the wan interface...
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
