Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CCM installation & ram issues
To my current understanding, os2000.4.4 and 2003.1.1 doesn't support more then 4GB of ram. I've got a DL380-G5 server, with 6GB of ram, of which, I wish to install CCM4.X, unity(vmware) and ipccx(vmware). Can anyone advise how do I go about fully utilizing the 6GB of RAM?
hannyong
Re: CCM installation & ram issues
You can try using Win 2003 on the server which should support 6 gb of ram.
but win2003 using the registry hacks? os2003.1.1 is only using "2003 standard server" not enterprise version. Win2003 standard version only supports 4GB of ram. Or am I missing out something?
You need Windows 2003 Enterprise.
For 2000, you need Data center to support more than 4GB of ram.
http://msdn2.microsoft.com/en-gb/library/aa366778.aspx
HTH,
Rate my post please.
Question is, how do I install win2k3 enterprise or any ms os which supports more than 4 GB of ram using cisco Os? Or in other words, which Cisco OS for DL380-G5 supports more then 4GB of ram?
Or you can try with SuSE.
110
