ccm-manager fallback-mgcp - Busy signal outside calls
jroussy
I start to configure MGCP for fallback, but each time I try to test the fallback outside calls are getting busy signal.
here the configuration :
boot system flash:c2800nm-spservicesk9-mz.124-24.T.bin
isdn switch-type primary-dms100
voice rtp send-recv
voice service voip
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw
voice-card 0
dsp services dspfarm
application
global
  service alternate Default
controller T1 0/0/0
cablelength short 110
pri-group timeslots 1-24 service mgcp
controller T1 0/0/1
cablelength long 0db
controller T1 0/1/0
controller T1 0/1/1
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn timer T310 120000
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn send-alerting
fair-queue
no cdp enable
interface Serial0/1/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn overlap-receiving T302 2000
isdn protocol-emulate network
isdn send-alerting
fair-queue
no cdp enable
interface Serial0/1/1:23
no ip address
encapsulation hdlc
isdn send-alerting
fair-queue
no cdp enable
voice-port 0/1/0:23
cptone CA
voice-port 0/0/0:23
cptone CA
voice-port 0/1/1:23
cptone CA
ccm-manager redundant-host **** ****
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server ****
mgcp
mgcp call-agent **** 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp ip qos dscp cs3 signaling
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface BVI1
mgcp bind media source-interface BVI1
mgcp profile default
sccp local Loopback0
sccp ccm 10.89.0.3 identifier 3 priority 3 version 7.0
sccp ccm 10.9.0.14 identifier 2 priority 2 version 7.0
sccp ccm 10.9.0.15 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface Loopback0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
associate profile 1 register CFB****
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 10
associate application SCCP
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
port 0/0/0:23
dial-peer voice 911 pots
destination-pattern 911
port 0/0/0:23
forward-digits 3
dial-peer voice 9911 pots
destination-pattern 9911
port 0/0/0:23
forward-digits 3
dial-peer voice 9411 pots
destination-pattern 9411
port 0/0/0:23
forward-digits 3
dial-peer voice 11 pots
destination-pattern 91[2-9]..[2-9]......
port 0/0/0:23
forward-digits 11
dial-peer voice 9011 pots
destination-pattern 9011T
port 0/0/0:23
prefix 011
dial-peer voice 10 pots
destination-pattern 9T
port 0/0/0:23
forward-digits 10
call-manager-fallback
secondary-dialtone 7
max-conferences 10 gain -6
transfer-system full-consult
limit-dn 7910 2
limit-dn 7911 2
limit-dn 7940 2
limit-dn 7941 2
limit-dn 7942 2
limit-dn 7960 2
limit-dn 7961 2
limit-dn 7962 2
timeouts interdigit 5
ip source-address 10.0.64.21 port 2000
max-ephones 96
max-dn 2 dual-line preference 1
system message primary Mode RELEVE - Panne MPLS
system message secondary Mode RELEVE
dialplan-pattern 1 514285.... extension-length 4
dialplan-pattern 2 514499.... extension-length 4
dialplan-pattern 3 514982.... extension-length 4
transfer-pattern .T
voicemail 1207050
call-forward pattern .T
call-forward busy 1207050
call-forward noan 1207050 timeout 10
time-format 24
date-format yy-mm-dd
2 Accepted Solutions
Tracy Larson
Level 4
Level 4
It doesnt look like MGCP took control of the gateway like it should have when creating the ports. You did configure them by clicking on them in the GUI I am assuming individually? In any event, add in these commands so that MGCP will control the ports accordingly.
dial-peer voice 999000 pots
service mgcpapp
port 0/0/0:23
dial-peer voice 999001 pots
service mgcpapp
port 0/0/1:23
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0:23
dial-peer voice 999011 pots
service mgcpapp
port 0/1/1:23
you will notice the tag after the "999" will indicate the ports that mgcp is controlling. Try that out, you may need to do a "no mgcp" "mgcp" after adding the dial-peers in there. MGCP should have added those for you though.
If you dont want MGCP to control a port on the gateway, get into call manager, bring up that particular gateway and delete the PRI port 0/0/0 from the gateway. Then verify on the gateway that the command "service mgcpapp" is no longer there. If it is, then get into config mode and remove the command from the voice port using "no service mgcpapp". I was on vacation last week so sorry for the late response.
28 Replies 28
Brandon Buffin
Does "show isdn status" show the PRI functional during fallback. You should see "State = MULTIPLE_FRAME_ESTABLISHED".
Brandon
Yes the "State = MULTIPLE_FRAME_ESTABLISHED".
Is the problem with inbound calls, outbound calls or both?
Brandon
Busy for both...
What digits are you dialing for the outbound call? If you enable "debug voip dialpeer", what dial peer is being matched by the outbound call?
Brandon
Thanks for your help, I had the following message :
Jul 21 09:48:26.733: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=10
Jul 21 09:48:26.733: //-1/77A162F18145/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=9514206xxxx, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=9514206xxxx
   Result=Success(0) after DP_MATCH_DEST
Jul 21 09:48:26.733: //-1/77A162F18145/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
Jul 21 09:48:26.733: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=9[2-9]..[2-9]......, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
LQ500-R99V#
   Result=NO_MATCH(-1) After All Match Rules Attempt
LQ500-R99V#
Jul 21 09:48:32.093: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=514285xxxx$, Called Number=, Voice-Interface=0x0,
LQ500-R99V#
Tracy Larson
Level 4
Level 4
try adding in the command "ccm-manager config"
This command enables the router to download the xml file from the publisher. This seperates out the H323 dial peers from the MGCP dial peers if any. I cant remember if that command needs to be added before the "ccm-manager config server" or not. In any event run a "term mon" and after adding in the command do a "no mgcp" then "mgcp" and you should see the xml file being loaded into the router.
We have a IOS version issue that dont work with "ccm-manager config" and create problems...
Tracy Larson
Level 4
Level 4
service mgcpapp
port 0/0/0:23
service mgcpapp
port 0/0/1:23
service mgcpapp
port 0/1/0:23
service mgcpapp
port 0/1/1:23
THANKS!
jroussy
I am now able to do calls from the inside to the outside.
But I still received busy signal from the outside to the inside. I will do some debug...
Get into Call Manager the go to Device, then Gateway. Find this paritcular gateway and click on the PRI's individually. Verify your setting are correct but then check the part that is in bold "Call Routing Information - Inbound Calls". Make sure your significant digits is defined correctly, i usually use All. Then verify you have the proper CSS defined for it that will include the paritions of your phones.
Edit: Your only problem is with being in fall back right? One more thing you should setup is more dial peers for each of the PRI's. I dont know how you have them trunked for inbound but sometimes only one PRI will get specified from the telco for inbound calls. By default I think the gateways should accept incoming calls with no dial peer configured for them but its best practice to have them configured for troubleshooting. So define another set of dial peers for each of your PRI's for outbound and inbound. Then once in fallback mode run the command "show ephone" to verify the phones are registered with the gateway accordingly.
I verify again, and the problem is there even if i'm not in fallback... So something wrong. I will have to reverify the hole configuration.
telnet to your gateway and issue the following commands and post the results here.
show ccm-manager
show mgcp
