CCM-MCS 7815 Server rebooting automatically
We have our Cisco CallManager 4.2(1) running on a MCS 7815 server, it was working fine till last week. And now since last week the server is getting rebooted automatically quite often...
And after the reboot I found the following error in the "Event Viewer"
"The Computer has rebooted from a bugcheck. The bugcheck was: 0x00000050 (0xe5b34ad0, 0x00000000, 0xbc69eabb, 0x00000002) Microsoft Windows 2000 (V15.2195). A dump was saved in C:\WINNT\MEMORY.DMP."
Have anyone come across such issue and can someone help me to solve this issue...
RV
Silver
Re: CCM-MCS 7815 Server rebooting automatically
Could be:
- a memory issue (try swapping RAM)
- Antivirus (check Event Viewer for that, especially if you are using non certified cisco antivirus)
- Driver issue (Audio/Video Card driver)
In addition to the good information provided in the previous post, I have come across this old field-notice for MCS 7815, which certainly describes the symptoms that you are experiencing.
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/products_field_notice09186a0080133e72.shtml
In light of the above, it would be recommend to initially replace the memory.
Hope this helps.
Allan.
115
