07-30-2007 10:50 AM - edited 03-14-2019 10:50 PM
I would like to know if there is anyone that has a cluster (pub in one location, sub in another location) replicating over WAN using a single point-to-point connection (1.5Mps)
Thanks.
07-30-2007 12:31 PM
we are currently running the setup but greater than 1.5mbps
However on another project that I was involved we did run a pub- sub over a t1 point to point, but the t1 was hardly use. i think it was 10% for data..something like that remember the rule between callmanager not to exceed 150 mileseconds
07-30-2007 03:24 PM
Please check SRND:
The minimum recommended bandwidth between sites that are clustered over the WAN is 1.544 Mbps. This amount allows for the minimum of 900 kbps for ICCS and 644 kbps for database and other inter-server traffic.
