CCM Passwords Change
Hi, I need change ccm login passowrds and I found the previous discussion at
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Phone%20Services%20for%20End%20Users&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddb4ad0
I tested in our lab and seems the steps for reset the private password phrase is the same as change the service ones. Is there any difference between them ? If I only change the administrator login password, do I need change the others one?
Wayne
1 ACCEPTED SOLUTION
Re: CCM Passwords Change
In call Manager 4.1.3, you only need to use the Adminutility to change the passwords.
Green
If I change the administrator login password, do I need change the others one?
NO, only make sure that all servers in cluster have the same Administraor password.
Hi Gonzalo, thanks for your kindly reply.
If change the private password phrase and service passwords, can I use the Adminutility one time to change all of them? I can't figure out the difference between the 2 procedures. They use the same utility and the whole process is the same per the documentation.
Wayne
thanks Kelvin!
121
