Community Member
ccm patches
hi
wht all patches i need to apply on CCM 4
also wht is the procedure.
i am bit sceptical.
do i need to simply install patches on server and it requires other services to be restarted.
regards,
1 REPLY
VIP Purple
Re: ccm patches
Take a look at the following document for approved OS, SQL and security updates.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/osbios.htm
Hope this helps. If so, please rate the post.
Brandon
106
