CCM : Phone User ID field is greyed
Dear Networkers,
I have CCM 6 installed.
Since some days i noticed that there is a phone that i cannot change the owner user ID. this filed is greyed for this phone.
(as u can see in tha attached screenshot)
Can you please help me how to enable this field for this phone?
Thanks in advance.
1 ACCEPTED SOLUTION
Re: CCM : Phone User ID field is greyed
By any chance is EM enabled???
if so, try disabling it
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
java
java
Unfortunately the Extension Mobility service is disabeled on this IP Phone :(
So the issue still persists !
Yeeeessss !!!
The "extension mobility" was enabeled on that IP Phone :) (the service was not subscribed to the phone , but it was only enabeled on it CCM>Device>Phone> as you can see in the attahced screenshot)
354
