CCM power failed...now it asks root password
Hello.
We have a CCM 6.0(1) in production that few days ago was shutdown improperly. Now, on boot, it asks for a root password (I guess in order to give maintenance to the file system).
Any idea about what to do??? (We've searched for the password and for any procedure in the cisco site, with no result).
Thanks in advance!!!
Cris.
Hall of Fame Super Red
Re: CCM power failed...now it asks root password
Hi Cris,
To get the root password you will need to open a case with TAC. Sorry man, but they can help gain access and get this fixed.
Rob
Thanks Rob for the quick answer.
Really only a TAC case would help??? o_O
I think this kind of problem should be common, because power fail are not unusual, and Linux always asks for root to give maintenance in those cases...
mmm...would be nice to have a documment about the subject.
Thanks and regards.
Cris
Green
Cris I have seen this error before
the system is in a status we cannot generate a root password.
What you need to do is to use the recovery CD and select options fm
If that does not help let me know...
I have the same problem since the last weekend, but at my site there was no power outage.
I start the CCM with the recovery CD and select the option fm. After this I press y for the for the force file system integrity check. The System check the Harddisk but found no error. I see again the error message Block bitmap for group 128 is not in group. (block 8388608) Unexpected Inconsistency; RUN fsch MANUALLY. without -a or -p options.
Any Idee?
Thnaks David
219
