Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CCM service keeps stopping.
Hi guys,
I did a fresh install of CCM4.2(3) on an MCS 7835-H2 with 1GB RAM and dual 18.2GB hard drives. The problem is that the CCM service keeps stopping. I get the following message in event viewer:
"The Cisco CallManager service terminated unexpectedly. It has done this 1 times(s). The following corrective action will be taken in 60000 milliseconds: Restart the service."
The only thing I can think of is that maybe I don't have enough RAM.
Any ideas guys?
Re: CCM service keeps stopping.
Hi Kane,
Even , I faced the Same Issue and Error at the time of fresh installation. After I put the CCM Server in the LAN, then I restarted the CCM(pub) Server, the CCM Service started working fine.
Then I identified that we need to put the CCM in LAN, at the time of installation and restart.
I think you can try the same for troubleshooting.
Kumar.V
Kane,
During installation, was CCM in the network or was it only a stand-alone machine? Also, are you trying to build a new cluster from scratch? ( I am guessing it's a new one ,judging from your mail). A few more details should help.
Hi guys,
Yes, the CCM was on the LAN during installation and it is still on the LAN. The ethernet port is UP and I can ping and browse to the server from another PC. This is a test CCM for a lab and it is going to be the only one in the cluster.
127
