Community Member
CCM time configuration
Hi, Can anybody tell me how to change the time setting of CCM?
Community Member
Re: CCM time configuration
Do you use NTP in you network ?
Community Member
No.. not really
Community Member
You can change time in bios of server and timezone through cli: set timezone
Community Member
that means do i have to restart the server and access BIOS to change the time? Any method to change without restarting?
Bronze
If you are using CUCM 6.X, go to OS Administration page,
Settings ---> NTP Servers . I normally, point to core switches as NTP Source.
Cheers
165
