CCM to CME connection...last question
If i configure the router running CME as an H323 gateway on the CCM will i also need to put the H323 commands on the router itself even though we are not using a gatekeeper?
i.e. h323-gateway voip interface
h323-gateway voip id
h323-gateway voip h323-id....
thanks for the help....
1 ACCEPTED SOLUTION
Gold
Re: CCM to CME connection...last question
No, you dont have to do this. You can configure the dial-peer to point to CM and on the CM add the Router as an H.323 Gateway, this should take care of things. Only thing that you can do is to do a h323 bind to aviod one way audio issues. Check the following link for information about the same:
http://www.cisco.com/en/US/customer/tech/tk652/tk698/technologies_tech_note09186a008009484b.shtml#h323
1 REPLY
Gold
127
