ccm trace files show 1 hour off
I'm using CallManager 5.1.2, I gather my trace files using RTMT, when I open the file the timestamps for each line are 1 hour off. Where do I check the system time in 5.1.2?
1 REPLY
Re: ccm trace files show 1 hour off
It is in OS Administration. Keep in mind however, that when you change the time, you will need to reboot your Subscriber (if you have one). The Publisher is the master time source for the cluster.
So since you are going to have to reboot anyway, rather than change the time, go ahead and set up an NTP server.
91
